MIDI Mapping Scroll Bar
Re: MIDI Mapping Scroll Bar
If you have the "Scroll layers and clips into view" enabled in preferences, then you can select any clip via midi or osc and then the window scrolls to its position.
edit: you can select the layer 1 clip 1 with /layer1/clip1/preview/ int 1 via OSC
Yes I could do this...but this will put some extra load to the system...and it's not that handy.
The idea is...just to map the scrollbar to a knob on a controller....
Greetings
geiras
Post by geiras »
+1
Kadete
Post by Kadete »
+1
mfo
Post by mfo »
I think I have a Deja Vu ...
+1
+1 ohh..me too.... :mrgreen:
This is confirmed, accepted and will be part of Res 6.
It's not going to happen in 5 anymore, so you'll have to wait a little longer I'm afraid.
