I WANT TO RUN RESOLUME WITH LOTS OF OUTPUTS! PLS HLP!
Alex Ramos
Re: I WANT TO RUN RESOLUME WITH LOTS OF OUTPUTS! PLS HLP!
Post by Alex Ramos »
My take is Watchout for the outputs and NDI from Resolume to WO
He2neg
Post by He2neg »
Nasr96 wrote: Tue Nov 04, 2025 12:31 just tested the following hardware on both pixera and resolume arena
amd threadripper pro 7965
asus wr90e sage mother board
128 gb ddr5 ecc ram
4tb 9100 evo (pcie 5 nvme)
rtx 5000 ada
2x rtx 4000 ada
monitor on 5000 ada (aslo set a high performance gpu for resolume)
findings
pixera : 8x 3840x2160 60hz ---->drops to 56-57 hz with 8 4k videos played back
resolume : 25.somthing fps just having the 8 outputs setup. gained 6 to 7 fps everytime i switch the output to virtualoutput
switched outputs to 1920x1080 still resolume dropped to 40 fps with 8 outputs active
Hardly a fair comparrison. Arena is not a just play this file machine. And if you need this then pixera is the better choice ;)
there are some litle things you can tweak to get resolume to the edge of what is possible.
For example: Did you disable the global effects in resolume
~Berlin~
