That will probably just duplicate the 8 bits of a color channel to the next 8 bits, won't give you 16 bit color depthwwwmwwww wrote: Tue Dec 02, 2025 04:14 I created a fixture inside resolume, then open the xml and edited with chat gpt, save, reopen resolume and voila.
Although it only work as a bug, if I open fixture settings and select RGB and try to go back to RRGGBB, it will not work.
16bit DMX fixtures and pixel drawing
Re: 16bit DMX fixtures and pixel drawing
[/quote]
[/quote]
That's definitely what will happen. The best solution would probably be for Resolume to add the ability to create fixture profiles with 16-bit parameters.
[/quote]
The most recent Resolume now supports working with 16 bit video. As far as I can see it is still not possible to do 16-bit parameters for DMX, right? Now would be a good time to add that feature IMHO.SailorJ wrote: Sat Dec 27, 2025 17:48That's definitely what will happen. The best solution would probably be for Resolume to add the ability to create fixture profiles with 16-bit parameters.Zoltán wrote: Tue Dec 02, 2025 09:38That will probably just duplicate the 8 bits of a color channel to the next 8 bits, won't give you 16 bit color depthwwwmwwww wrote: Tue Dec 02, 2025 04:14 I created a fixture inside resolume, then open the xml and edited with chat gpt, save, reopen resolume and voila.
16 bit video and composition rendering was possible since the v6 release.
The new feature in 7.24 is 10 bit output to hardware displays.
