I have this thing with A7....
francoe
Re: I have this thing with A7....
Post by francoe »
Zoltán wrote: Mon Feb 03, 2020 10:31 This 'only' affects windows machines with nvidia GPU-s as far as we know, so if you're on mac, or using AMD, you should be good.
I've said two times here, having this issue on plain macbook pro :?
boris.lema
Post by boris.lema »
francoe wrote: Mon Feb 03, 2020 23:31
Please, if you have the problem with a MBP. Try to force the problem, force a crash and note what you did. In the crash report tell what you did to get the crash and adress it to Menno. If we all just help a little bit we could speed up the progress.
Vjcheshire
Post by Vjcheshire »
Pretty sure my problem is different, but maybe its related to my other post on the forum.
For my indulgence, if you shake or move the resolume control window on your main monitor (not on the output monitors) does it cause stuttering and a drop in frame rate?
Vjcheshire wrote: Wed Feb 05, 2020 01:22 Pretty sure my problem is different, but maybe its related to my other post on the forum.
Yes, likely a different issue.
boris.lema wrote: Tue Feb 04, 2020 20:40
francoe wrote: Mon Feb 03, 2020 23:31 I've said two times here, having this issue on plain macbook pro :?
Yes, please.
Menno
Post by Menno »
Just a short update, we've narrowed this down to be caused by nvidia's api, which we are using to get gpu usage and vram usage. In 7.1.1 we'll be disabling this api usage. We've ran several tests (some running 5 days) and the problem no longer shows up :). As a downside it will mean that the gpu hardware stats will be less accurate or unavailable until we find another way to do it.
Thank you all for your patience and assistance!
p.s. if you have this issue on non-nvidia hardware, please create a new thread with the steps you're using to reproduce it and we'll look into it.
boris.lema
Menno wrote: Mon Feb 10, 2020 11:17 Just a short update, we've narrowed this down to be caused by nvidia's api, which we are using to get gpu usage and vram usage. In 7.1.1 we'll be disabling this api usage. We've ran several tests (some running 5 days) and the problem no longer shows up :). As a downside it will mean that the gpu hardware stats will be less accurate or unavailable until we find another way to do it.
Thank you!
So does that mean that all hardware read-outs are not accurate? That would explain the low CPU use and pretty high RAM use im getting on the No NVAPI version.
Menno
Post by Menno »
No this is just for the gpu usage and vram usage. You'll lose the gpu usage counter and the vram usage is now queried from extensions which may or may not be provided by the OpenGL driver.
The cpu and ram usage counters are provided by Windows so their precision is unaffected.
boris.lema
Menno wrote: Mon Feb 10, 2020 17:34 No this is just for the gpu usage and vram usage. You'll lose the gpu usage counter and the vram usage is now queried from extensions which may or may not be provided by the OpenGL driver.
oke! thanks for the info!
TPS
Post by TPS »
Using Windows 10 7.1.0 and AMD RX590 8GB card. Same problem here. :oops:
TPS wrote: Fri Feb 21, 2020 11:32 Using Windows 10 7.1.0 and AMD RX590 8GB card. Same problem here. :oops:
Please submit your crash report so we can check out what goes wrong for you!
