resolume 2.0 beta: post your wishes here
lucidhouse_
Post by lucidhouse_ »
You've got a point there Dan, but the layer effects could just be assigned within the effects panel (either asign effect globaly or to layer 1,2 or 3) ..I'm just woried that things will get a bit clutred where the main action happens, loosing that quick responce for live performances...thats why the right click, clear channel was great, nice big area to click on, split second access...
sensualvibes_
Post by sensualvibes_ »
Great work - thats what i did wait years for -
nearly all i waited for.
thx.
-Please connect the Flash variables to midi.!!!
- a trigger level, at the asound analyser would be great to start movies if peak arrived.
- the option to step frames sounddependent could get
a bounce action
keep on brothers
- Possible to plug the effects also between layers ?
sensualvibes_
thx.
a bounce action
keep on brothers
lucidhouse_
ok! I see what you guys have done with the "right click" on layer...( fliter effect settings from clips)
maybe see if the new clear layer button could be moved closer to where it was previously and made a bit bigger... it's too for off at the moment and a bit small for speedy action.
clear layer.jpg (42.84 KiB) Viewed 8776 times
thanx for all your suggestions so far! keep em comming! this is an importand thread for the future of resolume.
marcos_
Post by marcos_ »
first off, loving your work guys. been using 1.5 for 8 months or so and version 2 has been much anticipated. think the swap channel feature is great but would've been EVEN BETTER if all the settings jump up or down with the clip, it'd make transitions smoother ie: "DAMN WISH I'D PUT THAT CLIP ON TRACK ONE WITH THE BOUNCE TO THE BASS THANG SO I COULD THROW MY LOGO UNDER IT, AHA I'LL JUST SWAP CHANNELS. POO! MY AUDIO REACTION JUST DID A BUNK..."
in typing this i realise you could just copy the settings but when i'm all sweaty n really want to be dancing i'm not sure i'll always remember.
Love you all anyway.
[The extension swf has been deactivated and can no longer be displayed.]
metaprofessor_
Post by metaprofessor_ »
ok, i mentioned this wish a long time ago but i need to mention it again: i absolutely NEED the record folder to be user-specified so files can be recorded somewhere other than the resolume program folder (for most people, the drive that also contains the operating system). i'm sure that's not hard to implement! pretty please?
TurnT_
Post by TurnT_ »
I wish Resolume to play AVIs with sound
:) rest is perfect :)
Furionic_
Post by Furionic_ »
@ Metaprofessor: To change the record folder is possible! You even could do this in version 1.5. Just right click on record and you can specifie some things for recording like the maximum lenght, frame rate and the record folder you want to use.
Greez Furi
an-ism_
Post by an-ism_ »
It would be great to be able to update 1.51 decks into 2.0. I am able to load the old decks (1.51) however the timeline for the clips is lost. Thank you for making the BEST VJ app out there. BIG LOVE!
