FFGL plugins vote
hive8
Re: FFGL plugins vote
Post by hive8 »
Thing is I DON'T LIKE FLASH AT ALL, ITS WAY TO UNSTABLE... I need something that works and flash does not, that why its on the way out from a technology stand point, but could also be i just don't like it, kkkk.
hive8
Post by hive8 »
Rotational Clones Plugin, please have a look at it. I will add 3 features to it by tomorrow
* Alpha Blending between the clones
* Clone Stack Order Top or Bottom
* Open Radius for the clones (not based on 360 degrees, but whatever degrees are on the slider)
Please let me know how it works.
H8_FFGLRingClone.zip
(14.24 KiB) Downloaded 1290 times
hive8
Post by hive8 »
Here is the updated Version 1.002 with:
* Alpha Blending
* Clone Repeat Bottom or Top Order
For comments please reply here. Should I create a extra thread for each plugin in the developer section, to make it easier to follow with updates and feature requests?
H8_FFGLRingClone-V1_002.zip
Version 1.002
(7.14 KiB) Downloaded 1203 times
hive8
Post by hive8 »
Updated Version 1.100 with:
* Ring Degrees 0 - 360, allows to set the ring degree path
example: 360 degree full closed, 180 degrees half circle and so on
H8_FFGLRingClone-V1_100.zip
Version 1.100 WIN
(7.21 KiB) Downloaded 1169 times
hive8
Post by hive8 »
And finally here are the OSX versions of the plugins, please find download below and let me know if something doesn't check out, or isn't working.
H8RingCloner V1_100.zip
Ring Clone Version 1.100 OSX
(31.24 KiB) Downloaded 1198 times
H8Cloner V1_001.zip
Horizontal Clone Version 1.001 OSX
(13.71 KiB) Downloaded 1257 times
Sadler
Post by Sadler »
Bloody marvelous!
Great plugin Anton!!!
And yes it'd be great to have one thread for each of the plugins you create! That way it will make it easy to track them down later on.
A couple features that would be great to have:
- the ability to flip the clone on X or Y
- being able to do incremental scaling + or - on top of the original scaling so that one could create spirals
Frédéric
gavspav
Post by gavspav »
Thanks alot for sharing these.
Both plugins worked for me with Resolume/OSX but when I tried them with another host (Isadora) , only the rotate one worked, the other one crashed. If you want to follow this up mail me gavspav at gmail dot com
hive8
Post by hive8 »
I wrote you a email, let me know if you got it then we can see if we can get it running.
movebandit
Post by movebandit »
What about a simple Video Sampler ? One Parameter for Recording Start Stop, One Parameter for playhead Position of Sampled Video. Some Seconds to Sample should be Enough, just for Sampling and scratching a live Input / Master Output..
