wishes for new version
edward_
Post by edward_ »
i think that regardless of how it's implemented, there needs to be a way to adjust contrast. i'm really surprised that there's no contrast effect (that i know of at least). it's one of the most basic effects there is.
midnightvisions_
Post by midnightvisions_ »
>so,... what about a small step-sequencer (16/8 steps)?
>(posted by norm)
I would like to second that.
I'm still searching for a solution to tap in a beat and then trigger clips with a sequencer. It seems, that there is no solution except buying a hardware sequencer ...
Would be really great if the tapped in beat could also be assigned to effect parameters.
these features would make the best VJ-Soft on earth even greater ;)
DinkyToys_
Post by DinkyToys_ »
Choosing with an knobs (midi) an clip.
So, with 3 knobs you can choose the 3 layers with 2 knobs. Let's say when the clib is active for a half second the clip will be choosen and played directly.
charlie_
Post by charlie_ »
soft keying - like the v4
evomedia_
Post by evomedia_ »
The only thing I really need is to sync to midi clock, its the only request I have, just so I can use it for synced AV work. Whats the chances guys?
stark_
Post by stark_ »
1. larger video clip pannel with horizontal scroll.
or a way to fit more videos!! maybe saving the panel and opening new panels without messing up the current output (because when you do this and a clip is playing sometimes it crashes or it starts playing the video that is now in that place and not continue to play the other)
2. a way to play automatically with the background color from flash movies *now its just manual, in the way the freeframe plugins let you put a play and speed on the RGB settings in the colour filter
3. a way to limit the start and end parameters on freeframe plug ins, like the start and stop of a video clip. but for parameters like R G and B in the colour filter so that only certain range of values is allowed when the play funtion is on the parameter and it can play only in that range and start again or bounce. or whatever you choose.
ST-V
stupidus_
Post by stupidus_ »
maybe I´m stupid, but does resolume really work only with 20 clips?
stupidus_
Post by stupidus_ »
brent_
Post by brent_ »
I might just be missing where one can set this... but i'd really like to be able to assign a keyboard short cut for clearing a deck.
edward_
Post by edward_ »
i just thought of another key feature that's needed (i hope i'm not being retarded and this feature is already there):
there needs to be a way to specify the directory where recorded clips go. i nearly crashed everything at a gig by not noticing that it was still recording to the same drive as the OS. i wish i could record to my huge external drive.
the prog. is still making me famous in new york city, so i don't have too many complaints. thank you resolume!
