Resolume Avenue 3 Beta Now Available!
Re: Resolume Avenue 3 Beta Now Available!
I know that is a second time when I post this but I'm waiting for an answer as I cannot use R3 on my notebook. Has anyone tested R3 with this resolution 1680 by 1050 pixels with 32bit color quality?
You need to give us some more info as described here:konkhra wrote:I know that is a second time when I post this but I'm waiting for an answer as I cannot use R3 on my notebook. Has anyone tested R3 with this resolution 1680 by 1050 pixels with 32bit color quality?
viewtopic.php?f=13&t=3964
Here it is the report from OpenGL Extensions Viewer. And the Resolume's 3 log file does not exist. I've reinstalled my Windows with latests updates Sp3 etc.....the drivers from omega driver do not work with my video card but I found a solution to force the install. I've installed them and the problem persist. Now I'm using the original video drivers from lenovo.com website.
- Attachments
- glview-ATI MOBILITY FireGL V5250.zip
- (3.62 KiB) Downloaded 1451 times
Layers: I like Resolumes interfaces. However , I would like the layer section to be floatable or maximized in window option.
Text engine: any way to get text in , besides video clips?
OSC mapping: could we get specifics on OSC command mapping , routing, integers, floats, variables and more?
Resolume has great features that I like.
Things I am looking forward to are as follows:
Users guide in depth.
FFGL plugins.
Text input.!)
Final release.
So far, so good
FFGL plugins.
Text input.!)
Final release.
So far, so good
- gpvillamil
Yes, works fine. I'm using a Lenovo W500 with ATI FireGL 5700 graphics card. Res 3 UI runs fine at 1680x1050. The output screen works fine up to 1024x768 (haven't tested any higher).konkhra wrote:I know that is a second time when I post this but I'm waiting for an answer as I cannot use R3 on my notebook. Has anyone tested R3 with this resolution 1680 by 1050 pixels with 32bit color quality?
My notebook display is flickering like an old monitor with a very high resolution. For sure this is a bug.
Iwant to ask you if its avaliable the "FortyMinus" texts to use in resolume 3(MAC) cause i want get it rigth now. thank you for your attencion.
And thaks for your work too!!
peace and visuals.
feRda
peace and visuals.
The "FortyMinus" clips are all in flash and Flash i snot yet supported by Resolume 3. We are working on this and we will make it available as a free update as soon as possible.feRda wrote:Iwant to ask you if its avaliable the "FortyMinus" texts to use in resolume 3(MAC)
Will Flash have the same features like in R2 btw. ?
I loved the Flash- Variable Feature in the old Version. It gives the possibility to do kind of generative graphics or put multiple fonts in one Flashfile and so on.
c
c
Yes you will be able to send text and parameters, probably not the audio FFT anymore because it causes some overhead.cznickesz wrote:Will Flash have the same features like in R2 btw. ?
