had to have a go at this
Create Visuals with Resolume and Win an Arena License!
vjcontraband
Re: Create Visuals with Resolume and Win an Arena License!
- Attachments
mondrian.avc- (245.6 KiB) Downloaded 999 times
rebeloverlay
- Attachments
- resolume contest.avc.zip
- (9.93 KiB) Downloaded 1185 times
- freakiebeat
Be forewarned, the video quality is marginal due to re-encoding foobar - but load in the .avc and watch/play at full resolution. The gradient/line sources will have to be re-sized proportionality if you go to a different project resolution.
In an attempt to make things as transportable to another project as possible, all of the effects and key-mapped variables of 'Global Netz' are contained in one layer router except for the gradient hue changes and the number of lines.
Keymap cheatsheet - "A" (toggle/not really, just on) Auto pilot on / "B" (toggle) Background on-off / "C" (toggle/not really, just off) Cut auto pilot / "E" (mouse) Edge detect / "L" (mouse) Lines number [or] gradient alpha / "O" Opacity of gradient [or] lines / "Z" (mouse) Zooming.
'Global Netz - Static' is the project file in it's initialized state with no variable changes after load-in.
'Global Netz - Dynamic' uses key-mapping to play the project like an instrument... I was listening to Soulacybin when I recorded it.
'Global Netz - Soulacybin' is the dynamic clip set to music - "Ascending Satya" by Soulacybin - http://www.youtube.com/user/Soulacybin... click the link below to view
http://www.youtube.com/watch?v=Q4k2ibavyq8
PS> Bug hunt update - the "B" and "C" key-mapping breaks 'Auto Pilot'... and when actuating mouse key-mapping, once the mouse enters the 'Files/Composition/Effects/Sources' area, the key-mapping becomes sticky... to un-stick click the mouse in Mac and press a key for Windows.
- Attachments
- globalnetz.avc.zip
- (5.22 KiB) Downloaded 1018 times
VJ ChrisslyBär
Hi there,
Hope I got things right on the contest. But to be sure I post the 10 best Loops created with some Music and my two favorites seperately
Sorry for the bad quality ... my laptop is not doing well these days. New ones on the way delivery 3.April
Recorded with Resolume 4.0.0. Check check the constructionfile for better video-quality.
10-Loops (Music: Signal Orange - Sun)
The Living Cube
The Cristalin-Blackhole
Cheers and so long folks. Was hell of a funny contest
Vj ChrisslyBär
The Living Cube
Vj ChrisslyBär
- Attachments
Contest - Living Cube.avc- (31.71 KiB) Downloaded 1057 times
Contest - Cristalin Blackhole.avc- (52.78 KiB) Downloaded 989 times
Contest - 10 Loops.avc- (199.49 KiB) Downloaded 1062 times
THE ALLEGORY OF THE CAVE - Oldschool VJ Manual - by Plato
- Attachments
- Luwky - BrainGrain_.rar
- (104.08 KiB) Downloaded 995 times
# Independent Electronic Music Producer and Visual Artist
This is a sort of Ed Wood´s digital B movie, made in resolume naked soft.
Only Resolume Bb!
Only Resolume Bb!
- Attachments
- resolume contest.zip
- (25.63 KiB) Downloaded 1068 times
VJ SoulVision
VJ SoulVision - bouncing Square
- Attachments
Creation Resolum.avc- (58.8 KiB) Downloaded 940 times
at the later compositions is a dashboard link to use, the "resolume comp14" has 8 composition dashboards to play with
to play it correctly... start column 1, then the feedback in column2 and then the rest of the effect-layers above so that everything plays correctly!
- Attachments
- resolume comp 2_14 herrnieda.zip
- (121.34 KiB) Downloaded 959 times
Hello everyone!
There's a lot of good stuff already posted here, but in any case it was a lot of fun to play with it! Actualy, I have found that Resolume 3/4 is quie a workable tool for content creation (for old FreeFrame plugins I use FFRend for this purpose because of its ability to do non-real-time renders and access all parameters). So, here are my entries to the competition. I've made them in 720p, no post-processing, just cut them to make good loops.
cube-a-zoyd-3
dot-madness
cosmic-fishes
swirl-of-dots
flocks-of-dots
cube-a-zoyd-3
dot-madness
cosmic-fishes
swirl-of-dots
flocks-of-dots
- Attachments
- sources 720p.rar
- (10.64 KiB) Downloaded 850 times
- sources 720p cosmic-fishes.zip
- (8.39 KiB) Downloaded 870 times
- sources 720p dot-madness.zip
- (6.88 KiB) Downloaded 830 times
- sources 720p cube-a-zoyd-3.zip
- (9.75 KiB) Downloaded 936 times
