Resolume Avenue 3 is coming!
Re: Resolume Avenue 3 is coming!
craftycurate wrote: I use an Alpha Trail (or Wave) effect to create a cross fade between images, usually as a global effect. Will similar effects be available in R3?
Yes, Trails and Feedback are in R3.
craftycurate
Post by craftycurate »
Great thanks ... looking forward to v3!
incuf
Post by incuf »
Bart, you mentioned "Deadline Date" do you have a Date yet or it´s still end of september?
cheers
VjSky
Post by VjSky »
Just to bump my previous question:
Resolume Avenue is not compatible with integrated Intel graphics processors
Duh, does this mean that it won't work at all or is it only about quartz thingie? It would be very bad since both of my laptops have integrated intel cards :? :? :roll:
VjSky wrote:Resolume Avenue is not compatible with integrated Intel graphics processors
Avenue has roughly the same system requirements as Apple Motion and Final Cut Pro. Because all video processing is done on the GPU it requires a bit more than what most integrated intel cards (that are made for office not gaming or graphincs) can offer. Hope you understand that we have to move forward.
VjSky
Post by VjSky »
Yeah, ok, but some feature like software mode or something similar would be nice :(
So, resolume would completely fail to start if you ran it on an intel card?
Thanx :)
Rene
Post by Rene »
Rene wrote:Hi!
Is there any support for DMX in R3?
Sorry for re-posting this... but I cannot find any statement whether DMX will be supported in R3 or not. Did you kick this feature? Any others intereasted in DMX support - or am I all alone? :o
RTV
Post by RTV »
hi,
i just want to know if i can still use the zxpectrum emulator in rslm3 like in 2.4? and what chances of using other emulators ( nes, sega, c64).
thanks alot!
r t v
coz3r
Post by coz3r »
Rene wrote:
Rene wrote:Hi!
No Im with you dmx support would be siiiiick
_cozer
"Just because noone understands you it does not make you an artist"
djdiego71
Post by djdiego71 »
Please bart, tell me!!!!!!
Not more chaos option????? Is the most used option when no vj are present.
