please take 2 min 2 explain setup
gazelectric_
Post by gazelectric_ »
i have my first gig on monday 6th i am gonna use 1 moniter n 1 projector (gforce blah) i intend to film live bands and feed this into resolume while triggering loops through midi i am hiring the projector so testing will be limited. is there any issues i need to be aware of. cheers
we recommend running dual monitor .. just put the main interface on the monitor and the fullscreen output to the projector ... you can test this by getting a second monitor and connect that as if it,s the projector .. goodluck! and please test eveything thoroughly before you do you set!
kissout_
Post by kissout_ »
i only have one output on my card but i do have a splitter box will this work yhe same as two moniters how do i get the second monitor to be the projecter?
sorry for bein a pain in yhe arse
no need to appologise for asking questions ;-)
if you have a splitter you can not run dual monitor ... you have to switch back and forth to fullscreen mode ... to set the outup window fullscreen spress 'dual monitor' button and then press the small button in the far bottom left corner ...
good luck!
