Display a lot of pictures - Part 2
BlackBuda
Post by BlackBuda »
Well.
On the last Buffy, the Vampire Slayer:
"Buffy: Willom!!!"
"Spike: Buffy wait!"
ops, wrong tv channel. :D
Let´s continue.
The Mission:
Make resolume autoload and display many pictures in a folder
Idea:
Make a flash with actionscript autoload and slide the images.
After a little time, the simple code...: ;)
sequencia=1;
setInterval(load_photos,5000,sequencia); // 5000 = 5 seconds
function load_photos(){
if (sequencia>100){ // the last photo on folder
sequencia=1; // start again
loadMovie("/images/photo"+sequencia+".jpg","moldura_place");
sequencia++; // no arrays, just read the file sequence in folder, increment it.
The Fucking problem:
Work on flash, on web...
But on resolume just a Black screen...
any ideas?
ANY IDEAS? :/
[Edited on 29-10-2004 by BlackBuda]
Anonymous
Post by Anonymous »
hi BlackBuda,
did you set the timeline control of the flash clip to be controlled by flash.
right-click the channel, the choose timelinecontrol = flash.
this enables actionscripting in the main-timeline.
i can't seem to be able to download the file you attached.. can you zip it first...
cheers
Edwin
Danger
Post by Danger »
i can't download the .fla :(
but it seens like is resolume that is controlling ir .swf insted of flash player
BlackBuda
Post by BlackBuda »
Zipped.
autoimage.zip
(5.71 KiB) Downloaded 1170 times
BlackBuda
Post by BlackBuda »
Still not working
with flash control.
Sense
Flash Load Fader 2.0 - By Sense
Post by Sense »
Hi People, we coded just the thing you need lasts week. We needed it for a show. We made 2 parameters;
1. How long a pictute stays on the screen
2. How long the fade takes
You can download it from our site : http://www.friendsofsense.com/index.php?id=01148
Any questions or just need some explaination about the code, just drop us a line @ info@friendsofsense.com
Hope this works for you!
Cheerz,
nz|Sense
PS: At the moment it loads the pictures randomly, probably will add another parameter for random on / off in v2.1
PSS: blackbuda: I think your problem is with this line:
loadMovie("/images/photo"+sequencia+".jpg","moldura_place" );
try loadMovie("images/photo" + sequencia + ".jpg", _root.moldura_place);
so drop the / at the beginning, and the "" around your target MC
[Edited on 30-10-2004 by Sense]
BlackBuda
Post by BlackBuda »
Thks Sense,
Now it´s work :cool:
Thks.
