For some reason I can only make this happen on my MBP with 4.1.3 (10.8.2)
Even happens with a fresh install on a new composition, but only on the MBP, not my iMac or PC.
Fish Eye as effect clip with Luma Waves and Edge Detection as normal effects.
Only happens when right clicking on Luma Waves first then other parameters.
There is also no way to get them back after right clicking. If I change the parameter to another control type (dashboard, timeline, bpm) and back to Basic the slider is still gone. Have to shut down Arena and reopen to get them back
Parameters disappear
dirtyjohn_lv
- Attachments
- parametersMissing.png (47.36 KiB) Viewed 5272 times
Re: Parameters disappear
Is the MBP you're using the one in your signature? The 8,2 is the 2011 series right?
dirtyjohn_lv
That's it.
Well, I have a MBP from that same series, but for the life of me can't recreate this. Tried every combination of the three effects you mention, but no dice.
Did you install any new applications or updates lately that could somehow affect this?
dirtyjohn_lv
I have installed:
Caffeine
CS6 with latest updates
Lemur Daemon
Matrox PowerDesk
rekordbox 2.0.2
Scratch Live 2.4.3 (with Serato Video)
Really only frustrating when making new compositions, as I don't reset to many values live.
It may have something to do with Serato Video maybe, as that's the only thing that's changed in the past couple months other than an OS update.
It even happened when applying Shift Glitch to a logo tonight.
I blame my Mac, it has numerous problem and is on it's last legs I think
Caffeine
Lemur Daemon
Matrox PowerDesk
rekordbox 2.0.2
