BPM sync strobe
hive8
BPM sync strobe
Post by hive8 »
Most my visuals run in timeline mode, i would like to to add the stobe but sync it via BPM tap... Whats a good way of doing that?
Re: BPM sync strobe
hmmm... you can add a white or black solid on top of your layers... and animate the opacity to bpm.
Greetz
HerrNieDa
Re: BPM sync strobe
Post by HerrNieDa »
this maybe is to slow....
i would prepare video loops with black and white frames and lets say about 16 frames... so you can flash up to 8 times per beat!
other possibility which is not bpm sync is to use the timeswitcher for example on a white solid with invert effect.
hive8
Re: BPM sync strobe
Post by hive8 »
Thank you so far for the suggestions, the strobe doesn't have to be on to white, it can just be the main composition blinking in and out...
Re: BPM sync strobe
soooo..... black frames or solids are the answer! ;)
Rene
Re: BPM sync strobe
Post by Rene »
you could also put an instance of FrMultiStrobe to the composition. If I understood you correctly, it should be possible to achieve the same output.
hive8
Re: BPM sync strobe
Post by hive8 »
WoW great FrMultiStrobe does the trick, no fiddling around, just works as described, GREAT thank you for that link. Even has a flash button to just trigger it via a APC40 Button...
janeperry
Re: BPM sync strobe
Post by janeperry »
Thanks for the info guys!!! really helped! :)
Kenneth D
Re: BPM sync strobe
Post by Kenneth D »
The FrMultiStrobe really lock like a great fx. I however can't find it in resolume:( I have put it in my vfx library and restarted Resolume but it isn't there. Any one have an idea of what I did wrong? or is there another way?
HerrNieDa
Re: BPM sync strobe
Post by HerrNieDa »
Kenneth D wrote:The FrMultiStrobe really lock like a great fx. I however can't find it in resolume:( I have put it in my vfx library and restarted Resolume but it isn't there. Any one have an idea of what I did wrong? or is there another way?
some effects line up at the end after "Z"... just scroll down to the end....
otherwise the vfx-folder isn't set correct ;)
