64-bit
Hypnotist
64-bit
Post by Hypnotist »
when?
http://ljhypnotist.com
iMac 12.2, 3,4GHz/16GB/HD6970m 2GB/TB SSD-raid/DH2go
Arena 4, Modul8, Arkaos, MAX, QC, Unity3d, Madmapper
Launchpad,Maschine, RemoteZero SL, Bitstream 3x
kmifflin
Re: 64-bit
Post by kmifflin »
+1
Re: 64-bit
drazkers
Re: 64-bit
Post by drazkers »
+1
Re: 64-bit
Devil's advocate: Why?
kmifflin
Re: 64-bit
Post by kmifflin »
If you have a 64 bit CPU running a 64 bit OS, is not best to have 64 bit application. I'm might need to research my answer a little bit, but doesn't windows have to run addition threads to run a 32 bit application while having limited access to memory. If so does that make 32 bit applications less efficient on a 64 bit system?
kmifflin
Re: 64-bit
Post by kmifflin »
http://www.techsupportalert.com/content ... ations.htm
I guess it ultimately comes down to how much the WOW64 process takes away from the CPU that could Resolume be using.
I remember this conversation back in 98 when Windows 98 introduced a 32bit applications.
Hypnotist
Re: 64-bit
Post by Hypnotist »
bart wrote:Devil's advocate: Why?
4GB is not enough! We are dealing with HD resolutions now. Possibility to load more stuff to ram would be nice also.
Basic
Re: 64-bit
Post by Basic »
the footage decodes on the card, a better card may be needed. this has been discussed quite a lot in the past.
JQUEST
Re: 64-bit
Post by JQUEST »
Arena.exe has stopped working.
