hi!
I made this nice .swf with three dancers that respond to the rparameter1, rparameter2 and rparameter3 respectively.
When I load it in a channel and play it seems ok but then when I try to link these parameters to the audio it crashes really badly (blue screen and everything)
Of course you might say I should try making the dancers respond to the audio directly, not to the parameters...I´ll try that. But I´d apreciate if some brave resolume user can try this swf and tell me how it goes.
Thank you!
papui
MONUMENTAL CRASH using flash parameters!!
can one link rparameters to audio?
I made a new swf with the dancers reacting directly to the audio and it seems to work.
Is it some kind of bug that one cannot link rparameters to the audio? That would be a pitty because it would really be helpful if it would work.
I´d appreciate any feedback about this.
thanx..
thanx..
- Attachments
[The extension swf has been deactivated and can no longer be displayed.]
i don't know if it will help you
the last version of Macromedia Flash MX (PRO) 2004
have lots of bugs when "compiling" the swf...
i use it every day and found lots of strange bugs
they already have an update on the site that correct some of then, download it here:
http://www.macromedia.com/support/flash ... l#updaters
