recording avi with better resolution
marek
Post by marek »
is there any chance to save an avi file with resoution 800x600 or better when i hit the 'record' button in resolume 1.51?
thanks!
seex
Post by seex »
Resolume will record in the resolution that you set as your output resolution. For best results use an analog input of a dv camare record to tape and than capture trough firewire. Resolume record function is great in a live situation but if you make a long clip yopu will find that frames are being dropped.
