QC Png Import
Daniel
QC Png Import
Post by Daniel »
Hello Folks!
I tried to import some PNG's into Quartz Composer. Everything within Quartz Composer just works fine however ones I import it into Resolume, notting appears and everything stays black. Do I need to add some extra steps to make the PNG's show within Resolume?
Re: QC Png Import
Can you test with the boolean.qtz example from the QC example patches? http://www.resolume.com/download/QCResolumePatches.zip
Daniel
Re: QC Png Import
Post by Daniel »
will test it!
EDIT:
I tried it but that QC isn't working properly either. See attachment. It is just stuck in that position and doesn't react to anything else. Feedback doesn't work either.
Screen Shot 2013-06-21 at 18.51.26.png (10.43 KiB) Viewed 7296 times
Re: QC Png Import
Yikes, that looks pretty nasty.
Looks like something is going very wrong. Could you contact us directly ( mail@resolume.com )?
Daniel
Re: QC Png Import
Post by Daniel »
Sure will do!
