beta 2.2 black/white output
Anonymous
Post by Anonymous »
As i tried with resolume beta 2.0(test version -> not cracked) everything worked fine. now i installed beta 2.2 and the output is in bw also in 2.0 i set screen settings to dual monitor now just the second fullscreen is in BW and the preview on work window is in color ???
please help me out ! today is a gig :(
Anonymous
Post by Anonymous »
help please iam dying my gig is in 2 hours and i cant solve the prob !!! please help !
levon
Post by levon »
it would help if we knew what gear you had.
everyone comes in hear saying there problem, but how are we ment to know what might be the cause if you dont give us any information
oh i guess its to late now anyway, how did your B&W gig go? :P
[Edited on 21-11-2004 by levon]
Sense
Probably a cable problem
Post by Sense »
you probably used original s-video cables on your s-video out on your lappy. On earlier tries you used most likely composite cables.
The ancient YUV-problem
sense
[Edited on 21-11-2004 by Sense]
Anonymous
SOLUTION
Post by Anonymous »
ok...
problem solved
i changed my grafik card Opengl and directx driver option of my radeon 9700pro
when i put them back to install stadium that solves my problem, probably(of shure) the ati driver is not very constant in harder directx settings than factory defaults
thanks,,, my gig was famous from 23.00 till 9 in the morning
i will test my system and resolume to bring an exactly error report and fixings for this prob.
mahlzeit!
Anonymous
SOLUTION
Post by Anonymous »
ok...
problem solved
mahlzeit!
