Actionscript-Problems
michaONE_
Post by michaONE_ »
I sometimes have Problems with Flash5-Actionscripts!
When I load some .swf-Files with Flash5-Random-Actionscript-Functions into RESOLUME, every 2nd/3rd time the software broke down!? Can´t control or analysing, where the problem comes from!? are there any rules of F5-Scripting???
who could help or have any experiences in those F5S???
Thanx.
resolume ignores any frame action scripting ... if we would just let flash do all the playing then we would not have speed and scratch controls over the movie ... this is in order to give consistent functionality on movies, flash and pictures.
b blaze_
Post by b blaze_ »
is there any way to toggle this feature on and off? I've been looking for a VJ app that supports Flash 5 for a while. Looks like I may have found it except from the sounds of it it won't work properly... Going to test it out when I get a chance, but "frame actionscriptin" sounds like what I rely upon...
yes we are thinking about making a toggle indeed ... if we can find the time we will do it ...
YO_
Post by YO_ »
If you want to Mix only Flashfiles/swf´s, you can use this brand new software!!!
http://www.vlight.to/MXR/
have fun. but remember every time - RESOLUME IS BETTER !!!
