setting reset
VJzoo
setting reset
Post by VJzoo »
The other day when I opened resolume I accidentally opened it twice.
I closed one and started up my midi trigger (dm2) and when to check my settings and there was nothing in the settings menu, I then all the other menus (e.g. filters) and they were all blank.
I closed resolume and then opened it aging checked my settings and all the options were there but all the midi settings I had set up had been erased :(
Not happy.
Ill have to be more careful next time ;)
VJzoo
Post by VJzoo »
just reposting the image :)
DAS BEN
Post by DAS BEN »
resolume really likes to loose the preferences. you have to make a saftycopy of your fff-files: short.fff and prefusers.fff.
greetings das ben
VJzoo
Post by VJzoo »
thanks heaps for that : )
