Hi everyone,
I'm looking for a affordable camera to be installed in a venue that feeds directly into a projector.
Could anyone give me some recommendations?
Many thanks!
Camera for stage use
Re: Camera for stage use
Hello
if you want to plug it directly to projector you can go for gopro via hdmi conection.
fruitygreen
What range is affordable for ya?
What is your max budget?
What features you need?
GoPro has fixed lenses.
If you need variable focal depth and budget HD , check out Craiglist in your area for HD cams. They usually have outputs compatible with majority of projectors.
