Hello,
I want to buy a Macbook second hand and I have to choose between 2 config. Which graphic card is better for resolume gt330m 256 mb or 9600 gr 512 mb?. How about automatic graphics switching in 2010 model is it ok?
1. MBP MacBook Pro i5 Mid 2010
- Display 15"
- Hard Disk 126 GB SSD
- 4GB DDR
- nvidia gt 330m 256mb
2. MBP MacBook Pro 2009
- Display 15"
- Hard Disk 320 GB 5400 rpm + 128gb ssd
- 4GB DDR
- nvidia 9600 gt 512 mb
please help choose which MBP is better for resolume
Re: please help choose which MBP is better for resolume
If you get the GT330m make sure you don't get the faulty Nvidia chip I had that one and apple wont replace it anymore. Also i upgraded mine to a SSD, this model only features the 3GB SATA connection instead of the 6GB.
