APC 40 & Touch OSC together
He2neg
Post by He2neg »
Is it possible to use both at the same time ?!
If NO : damn it! why not ?
If yes :
-is it possible to controll the composition effects with the touchosc ( allways reachable) no matter what i do with the apc or the mouse ?!
- were to get some good touch osc interfaces ?
- Is touch osc only possible over w-lan, not via a usb connection ?!
This is it for the time but there will be more question if there is someone to answer...
Thank you guys
~Berlin~
He2neg
Re: APC 40 & Touch OSC together
Post by He2neg »
okay few hours testing...
i wasnt able to connect the ipad with my windows based laptop.
it find the osc bridge and my pc as a host but not more.
all the howto i found couldnt help me... maybe some1 around here fought this battle allready ?!
~Berlin~
najrock
Post by najrock »
Yes. It is possible and rather easy. There is a wealth of information on connecting touch osc on their website and even more YouTube videos of pretty much everyone with an iPhone and a computer controlling something with touchosc. Create a network>connect ipad to network>confirm send and receive ports are all proper>touch away
Resolume even makes it easy for you to program the osc commands if you turn on osc mapping (cntrl alt O?) you will see the proper syntax in the info window on the bottom left
Then you can throw away your shitty apc cause you are probably sick of bending the faders and searching for a bag for it and get a livid and connect it at the same time as the ipad
Touch osc sux tho get the lemur app
He2neg
Post by He2neg »
ok i made it... thx for the help and maybe i just didnt try hard enough...
~Berlin~
