Application / composition map list
hi.
you can assing to composition key map the same keys that were used as default in application key map, and/or allready have been assigned to do something. This has caused some interesting moments for me :). Could you add a warning message, or just a list of the same key assigns if a user wants to assing a key(or midi note) thats allready assigned?
and maybe a full list via menu to list all assignments.
Re: Application / composition map list
Thanks for your feedback!
Assigning shortcuts can indeed be confusing. We'll be doing a lot to do make things clearer in Res 5, among which your suggestions of warnings and a list of assigned shortcuts.
