hi!
is it possible to set the Live Feed Resolution manually and independently of Project Resolution? For example my project is in 1280x720 but I want to add a video source but set it resolution to 640x360.
ReggieUnderground
Re: Live Feed Resolution
Yes that will input fine. Then you can manually set whatever resolution you want in the Clip parameters for the live feed source clip.
But how can I do it? I don't see any option to change it in the Clip.
What kind of live input are you using? Are you using a capture card or the built in camera on your laptop?
