Hey Folks,
while i want to test the Benchmark of my System i stumbled /again/ over some weird issue.
It happened already sometimes but i never thought about it after it.
I downloaded some Videocontent ( vimeo / vj loops / etc.) This time the Benchmark test package.
After i copyed the files to my USB Stick ( i tryed 2 different) and again transfered it to my VJ laptop the Files are broken and Resolume cant use them ( the yellow X as symbol)
-Tryed different USB sticks
- On the PC i downloaded the Content everything works fine
Do every someone of you had this and also may have a explanation for this ? Or even better a Solution ?
Files broken afer transfer via USB Stick
~Berlin~
~Berlin~
Re: Files broken afer transfer via USB Stick
OK... NOW IT´s getting super weird / or i am super Stupid
I downloaded the files on directly on the VJ Laptop and they are brocken as well their
What did i miss ? Pleas tell me ?
Other Files in DXV work fine.
~Berlin~
~Berlin~
thedawjones
How are your drives formatted (NTFS or Fat)?
Macs can read but not write to NTFS drives, try formatting them as fat32.
Only thing I can think of.
Sry. Both windows 7 systems
~Berlin~
~Berlin~
Can you post a screenshot of how the files look in the Res browser?
yes i can ...
i realy think my Laptop is missing some Codec/ Addon whatever.. because it´s quite new
- Attachments
- "Broken Files"
- screen.jpg (33.2 KiB) Viewed 10104 times
~Berlin~
~Berlin~
Strange. Do you have Quicktime installed?
ööhmm.... Huops ... Nope....
i will install it later that day and let you know if this fix the problem....
~Berlin~
~Berlin~
Sry for the long time to respond, was ill.
Yes the Problem is Solved after Quicktime is installed.
Strange that other .mov / Dxv files work and some others dont.
Nevermind, i thank you for the Help.
~Berlin~
~Berlin~
