Laptop with two graphic-systems
nilsherb
Post by nilsherb »
Hi, i use a laptop with two graphic systems (intel & nvidia).
When i start resolume and use the info setting on outputs, the info always says that intel graphics is in use.
In the nvidia system panel i already connected resolume.exe with nvidia graphics.
How can i get the nvidia graphics system to work with resolume?
Greetings
Nils
Re: Laptop with two graphic-systems
look at the log file
Preferences - Feedback - view log
search for
---Info main OpenGL renderer---
there you will see which card resolume uses to render.
I have a dual setup too with intel 4000 and amd radeon and the info shows the intel card, but the radeon is used.
He2neg
Post by He2neg »
if you use Nvidia Optimus ( the new one) you can assign resolume as Program to be used with your main card.
Right click the shortcut or the .exe and look there.
~Berlin~
NexusVisions
Post by NexusVisions »
