I'm pretty new to advanced networking/ plugging and using various sources into specific programs.
I was hoping if anybody would be able to help me out with getting programs to work within Resolume such as Macromeez visuals - http://www.macromeez.com/macromeez-visuals
Its a brilliant program you can control live and would make a great backdrop to add more layers upon in Resolume.
My best guess so far is that i have to have it running on one computer with a screen capture and Resolume on my main computer which has the projection output and somehow tell Resolume to stream this screen capture as a clip?
After Effects would be pretty cool to be able to stream in as well or a painting program like Corel Paint which i think Android Jones does for some of his shows?
Sorry if this has been asked before i tried searching the forums but it seems most of the topics being discussed are a bit advanced in regard to what im trying to achieve currently!
Cheers
