Windows 8.1 can i upgrade?
Is it possible now to upgrade to windows 8.1, i remember there have been some problems before, have they been worked out? If YES that be super great, since i could start using airserver with miracast.
Re: Windows 8.1 can i upgrade?
There's only one problem we currently know of with Win 8.1:
If your dekstop scaling is not set to 100%, Resolume can report wrong resolutions for your outputs, or even 0x0 in some extreme cases.
On some screens Win 8.1 will set your scaling to 125%, so this can be very confusing.
We're working on fixing it, but for the time being you can just make sure your scalings are set to 100% : http://winsupersite.com/windows-8/hands ... ay-scaling
Thank you for the reply, I will keep this in mind and set scaling to 100%.
vj Lambency
this was doing my head in. Thanks!
