2 GTX 780
dirtyjohn_lv
Re: 2 GTX 780
Yes
Re: 2 GTX 780
You could use MST Display Port 1.2a technology to get 12 displays using an MST Hub on each card.
Also, keep in mind that two GTX 780 in SLI will be awesome!
Re: 2 GTX 780
If its in SLI, can i still use all outputs?
Re: 2 GTX 780
Hey there...
Just to remind here:
SLI nor crossfire configurations will have any positive performance effect with Resolume.
//Reminder end
greetings
//Reminder end
greetings
Do you like outlines? Easy Outliner on Juicebar Re: 2 GTX 780
No, SLI or Crossfire turns one GPU into a slave and uses it for calculation.AmielG12 wrote:If its in SLI, can i still use all outputs?
Re: 2 GTX 780
Is that 100% sure. One of my rigs has two R9 270X 1050M 2GB in crossfire and I've consistently by clocking above 80fps in Resolume Arena 4 and it's rock solid with large comps whereas I'll get 60fps when I disable crossfire.cosmowe wrote:SLI nor crossfire configurations will have any positive performance effect with Resolume.
Re: 2 GTX 780
Yes. Never read anything positive about sli or crossfire here in the forum. And as far as I know Resolume does not support it.Is that 100% sure
If you get 60 fps without and 80 fps with SLI activated while showing nothing in Resolume there must be something else causing your 80 fps. Maybe Win Aero? When I deactivate Aero I get up to 90 fps.
Is your output in windows is set to 60Hz?
Best regards
Maybe someone from the Resolume support team can enlighten us?cosmowe wrote:Yes. Never read anything positive about sli or crossfire here in the forum. And as far as I know Resolume does not support it.
Not sure what you mean by "while showing nothing in Resolume" but the only difference in the setting would that Crossfire is activated in Catalystcosmowe wrote:If you get 60 fps without and 80 fps with SLI activated while showing nothing in Resolume there must be something else causing your 80 fps. Maybe Win Aero? When I deactivate Aero I get up to 90 fps.
Yes, my last setup was a 3840x1080 comp scaled up into 3 @ 1600x1200 @ 60Hz projectorscosmowe wrote:Is your output in windows is set to 60Hz?
Best regards
cosmowe[/quote]
Re: 2 GTX 780
I've made a fast search: viewtopic.php?f=7&t=8535&p=33439&hilit=crossfire#p33439
Joris: Adding more GPUs to the mix will not increase performance.
