matrox triple head to go problem
vinayak gurram
Post by vinayak gurram »
im using triple head to go product. the problem is that im using only two outputs one is for centre display and second output is for left and right display .. now left-centre and right display should be linked to each other so that it makes one whole screen...
please if anyone have the solution to this problem please revert back ..... ;)
dradutu
Re: matrox triple head to go problem
Post by dradutu »
i know it's almost a month since you posted but i was bored and i made a screensetup for a 800x600 comp
vinayak.zip
put this in your /screensetup folder and it will show up as a preset in your advanced screen setup window
(800 Bytes) Downloaded 1042 times
