resolume in window mode (URGENT!!)
Anonymous
Post by Anonymous »
I got a geforce 6800GT, the beamer is connected to the TV out.
I use horizontal desktop (there's no other option, DVI wont work) and when i start resolume, one half of it is on the LCD screen and the other half on the beamer.
But i want the controls on the LCD screen and the output on the beamer.
To reach this, i have to DRAG the output window to the beamer's half and scale it to fullscreen.
Now, i have to SCALE the resolume controls to the LCD screen.
THIS IS NOT POSSIBLE; BECAUSE RESOLUME DOESNT ACCEPT WINDOW MODE, and that really sucks.
Why is there only fullscreen??????????
How do i solve this problem??? How do i scale the resolume controls???
PLZ REPLY QUICKLY!!
THX!! Julo
cat
Post by cat »
Have you enabled dual view (or twin view) its usually at the end of the list of output types horiz span vert span clone etc. Without it clone mode and theatre view might do it, never tried, I use dual view.
Other options if its a gig tonight beta 1 or 2 work? or 1.5. Else update or resinstall all your drivers and try again!
Other things to check, when looking for a dual view option is you tv out connected, have you checked the my TV is connected but not being detected button(always handy)?
Could try TVtool http://www.tvtool.info I think, which may help or not!
Good luck
cat
