maybe i am blind, but....
grobkorn
Post by grobkorn »
heho,
maybe i´m totally confused, blind, stupid - whatever ;) - but i cant get any information about following feature... maybe i will never use it - but im still curious ;)
what does that ">" mean - right beside 1st clip column?
thanks ;)
Re: maybe i am blind, but....
Hi Grobkorn,
Hmmm.....I really have no clue....but I want it! ;)
This is so you can program one button to advance columns in and I believe it's available in MIDI and DMX.
grobkorn
Post by grobkorn »
aaah. i see... i always mapped this to midi note - but never to CC...
btw
why is there no STEP-option for midi notes? ;)
thanks!
He2neg
Post by He2neg »
what does it do ?
just map it and try..
~Berlin~
dirtyjohn_lv
Post by dirtyjohn_lv »
My question is, why is this only visible when in mapping mode? I had no clue!
Maybe make it visible as part of the transport controls?
drazkers
Post by drazkers »
Map to a fader or knob and you can scroll through clips.
You can also trigger next column when you map the [>] next to [Column 1] which I use all the time to cue theatrical shows with a very basic MIDI controller.
machfox
Post by machfox »
aaah. very useful for me as well! thanx.
chenthemagician
Post by chenthemagician »
Doing a production in Canada, and using it in an empty layer...to scroll thru my deck...awesome... :D
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
Livid OHM RGB Controller
Creating Solutions, Tailored to your needs!
Repping from the 876 - Jamaica "Out of Many, One People"
