Refurb 2012 MBP or new MBP?
thebassist
Post by thebassist »
No more than 5 layers in Resolume/CoGe, but running Ableton as well... Needs to be bullet proof. Low resolution.
So which would you get? A refurbished MBP with a designated video card, or off-the-shelf current MBP without a video card? The current MBP with video card is out of my budget.
Thanks for your time and input.
He2neg
Re: Refurb 2012 MBP or new MBP?
Post by He2neg »
you ll need the extra videocard for sure...
so go with the older on... or think about windwos...
~Berlin~
thebassist
CoGe is Mac only, and I use both.
