Hi, I'm using your projection mapping software on a Mac and would like to project a shape that then evolves and gets smaller (in relation to an object in a video). Is there a way I can move the boundaries throughout the video? Also, is there a way I can sort of attach the boundaries to an object so they change as the object changes? It's just a rotating pyramid, so it's no too complicated a shape and has straight edges rather than curves.
Thanks, Claire
Changing Boundaries
chenthemagician
Re: Changing Boundaries
Hey Claire, welcome first of all...
Sounds like you want to set up some type of mask on a layer above your video, and then control the size of it via hotkey, be it keyboard, MIDI or OSC, preferably the last two...
2 cents from hot Jamaica...
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
Livid OHM RGB Controller
Creating Solutions, Tailored to your needs!
Repping from the 876 - Jamaica "Out of Many, One People"
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
