Where did all my HDD space go?
rawdesigns
Post by rawdesigns »
So i got a 500 SSD and I just noticed I should have more space than it says. I have disk cleaned and defraged.
You can see when I go to Users file (just me btw) that 223GB's is being used
User file 223GB used
When I go into the folder there's only about 10GB's used as you can see by the file size of the other folders. (the ones hidden either don't show me the file size or they are only a couple MB's
Ryan folder only 9.72 GB
Public 529MB
Public 529MB
dub_cm_auto 3.55 MB
dub_cm_auto 3.55 MB
There's clearly space missing! No idea where it's gone. please help!
dirtyjohn_lv
Re: Where did all my HDD space go?
Post by dirtyjohn_lv »
Windows 10 hasn't been reporting proper folder sizes for me at all.
My user folder is 8GB, but My Documents is 7GB and the AppData folder is 3GB. Maybe that's a new "feature". The files inside My Document only add up to 6GB for me.
What does the General tab of the C drive say you have for space?
He2neg
Post by He2neg »
My guess :
System recovery points.
~Berlin~
AdevProjects
Post by AdevProjects »
You should use a free tool called windirstat. It shows you what files are using up your space.
http://windirstat.info/
rawdesigns
t13swift wrote:You should use a free tool called windirstat. It shows you what files are using up your space.
wow this works great thank you! stupid Adobe had 2,000 + files in the Cache :x cleared up over 100GB
Basic
Post by Basic »
Its always a good idea to use an external HDD as a cache drive.
