Collect files for a project?
adamlewen
Post by adamlewen »
Hi there!
Is there a way of "collecting" files so that all the files used in a project are in ONE FOLDER?
Lets say i build a project with different files from different locations, now I want to put all the used files in the same folder and have my project nice and clean...?
This method might have another name
Thanks for any tips!
Adam
Re: Collect files for a project?
adamlewen
Post by adamlewen »
wow!
I hope I will make it work here!
adamlewen
Post by adamlewen »
cosmowe this is an amazing little app!!!
Am I doing something wrong if my project gets collected (like I wanted) but when I play the AVC project file I need to re-connect the media, and once I do that all the clip properties are back at default...? (trim, bounce play etc.)
maybe I should play with it a bit more...
But amazing work! Thanks for sharing.
adamlewen wrote:cosmowe this is an amazing little app!!!
that should be fixed in resolume 4.2.2 I think
smoresahoy
Post by smoresahoy »
Does anyone know if this works for arena 5?
SystemD
Post by SystemD »
smoresahoy wrote:Does anyone know if this works for arena 5?
Yes, it works
Nolaz
Post by Nolaz »
Hello,
sorry but I don't understand at all the philosophy of Arena to save a project...
How to export a project (on an external support for example) while being sure not to forget anything (clips, advanced outputs, presets, user fixtures, etc...)?
It's all in different directories. Is there any other way than to copy and paste elements from each directory?
Thank you
Nolaz wrote: Sat Jul 06, 2019 15:25 It's all in different directories. Is there any other way than to copy and paste elements from each directory?
Yeah, this needs some attention, and we have a ticket for it.
For now, collecting the composition and files to a folder, then copying it along with the Documents/Resolume Arena folder to the new machine should bring all your files and presets you used with you.
You can also be more specific and check the used presets in the shortcuts, and Advanced output, and copy those and the Fixture library also to the corresponding folders.
