shader issues
dirtyjohn_lv
shader issues
Post by dirtyjohn_lv »
Not sure if this is how ShaderLoader loads the shaders, or how Resolume renders.
Anyone know why this shader acts different in Resolume than it does in web browser?
https://www.shadertoy.com/view/MdfGRX
Sadler
Re: shader issues
Post by Sadler »
I can't say categorically but it's likely that ShaderToy implements certain features in certain ways and the ShaderLoader emulates as much as it can. Other applications that support ShaderToy and GLSLSandbox don't support every feature. For instance ShinyTreat will not even run since it uses textureCube which isn't implemented.
