midi problems
norm_
Post by norm_ »
hey,
Resolume 1.1 works on my machin, so far, fine. Except: I tired to bind some MIDI-Notes and ALLWAYS when I press a MIDI-Key the prog crashes...
In resolume 1.0 it worked fine.
my PC: 1.4 GHz Athlon, 256 MB, G400 16MB, MIDI-Box (16 pot-controllers) on the onboard VIA 686B controller and a SB128 (CT5880) as 2nd MIDI controller
Loup_
Post by Loup_ »
I enjoyed exactky the same problem,
I thought it was my system that leads resolume to crash ?
we,re on top of this guys!
Loup_
Post by Loup_ »
Well, maybe,
Am I the only one that have that midi bugg?
Every single midi signal that resolume receive, leads to a crash. And it worked fine in the 1.0?
config: PIII 1Ghz, 512 Mb, G450, Midi Yamaha DXG / hoontech SoundTrack Digital XG PCI, asus CU4-V
kaypohl_
Post by kaypohl_ »
my config - thinkpad a20p - pIII 850mhz - 512mb - yamaha ux96 midi to usb
and finally it works with beta 2!!!
thx for that midi-improvement although i dont know why it wont work at the others ... hmm
just love resolume!
greetz,
kaypohl
venom_
Post by venom_ »
It crashes in my case too! I am not able to fully test resolume. Will there be a new alpha/beta soon? If
this feature works fine I will definately order a copy!
kristian thomas_
Post by kristian thomas_ »
i found that the problem to the bug was to make sure your midi device was not sending out any system exclusive messages.
kt:)
an-ism_
Post by an-ism_ »
I still can not get resolume to run midi it just crashes as soon a key is pressed. I see (above) this problem is common is there any progress on a solution?
