Simple Tile Mirror Plugin
hive8
Post by hive8 »
Here is a simple Tile and Mirror Plugin, based on the aftereffects plugin Motion Tile
You can scale the input Tile
Repeat or Repeat Mirror the input
Set the anchor point (tile center)
This is version 1.000, please test and let me know if you find something not working or want to add something
I will shortly add all these plugins on my website with a donation button :)
OSX version will follow shortly
H8_FFGLTileMirror.zip
WIN version
(8.27 KiB) Downloaded 1338 times
Kadete
Re: Simple Tile Mirror Plugin
Post by Kadete »
AWESOME!!! :D :D
Sadler
Post by Sadler »
Thanks for yet another plugin.
VideoWall does more in terms of tiling (though it would be good if VideoWall's pan and rotate were seamless) and can be combined with Slide to match this plugin (sans mirroring).
Also media smaller than the comp seem to be shifted to the left and down a little when tiling is turned on.
Appreciate your efforts as always.
hive8
Post by hive8 »
Sadler wrote:Thanks for yet another plugin.
If you move the transform node before the plugin that should fix the shift. I will look at the other suggestion.
Could you explain point one a little more
Sadler
Post by Sadler »
H8 Tile Mirror's tiling seems a bit limited when compared to other tile options.
Your built-in mirror and slide are good additions.
damstraversaz
Post by damstraversaz »
thanks a lot for sharing !
radial and horizontal cloner seems to be very interesting too, the donation option for all your work will be great !
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
5AMvisual
Post by 5AMvisual »
ETA on the OSX version ?
I'd love to work with this :geek:
Sam
  • HacPRO (Win10/OSX10.13 Render+Mediaserver)
  • i9 9900K OC - 64Gb RAM - NVIDIA Titan Xp 12 GB VRAM
  • MBP 2018 15" - Livid Ohm RGB - Arturia BeatstepPro - DJTT Midifighter Twister
  • Bome MTP - Vezér
hive8
Post by hive8 »
Yes I am adding the code right now to OSX should be done in less than 24h... Maybe before, I try to do it while in the middle of a film shoot LOL.
Hey Hive8, where do you find these new plug ins on your website?
hive8
Post by hive8 »
the website is not made yet will be by the end of the week tho
