About Chaos and TRansparency
djdiego71
Post by djdiego71 »
I wish a more programable chaos like sequential, and the posibilitlity to separate decks for each layer.
And set the transparency on each channel instead layers (specific clips need some particular transparency)
Thanks for listen us, bart & ed!
we have plans for the chaos mode so that will be comming but what exactly do you mean by saying: separate decks for each layer?
levon
Post by levon »
i think what he is saying is that he wants to beable to assign some clips to layer 1, others layer 2 etc.
this can already be done by RMB on the caos button.
djdiego71
Post by djdiego71 »
Sorry about my english:
my idea is this: set some decks on layer 1, anothers on layer 2, etc. and each layer should have their own time control.
thanks.
levon
Post by levon »
you already can set some decks to layer 1, others to layer 2 etc. RMB on the caos button
djdiego71
Post by djdiego71 »
Not, levon, you can set any channel to layer 1, anothers to layer 2, etc... but can't set decks for each layer. The decks you set contain all clips to used when switch to it on the layers.
My idea is set decks for each layer, then you can put 80 backgrounds loops on deck 1 to 4 (for example) and set to layer 1, put 20 text loops on deck 5 and set to layer 2, and finally put 40 vector loops on deck 6 to 8 and set to layer 3. Each layer with their own "Deck time switch" and "channel time switch" and eliminate the "layer time switch"
I hope that my explain will be clearly.
Anonymous
Post by Anonymous »
it would also be nice if there's a possibility to set the switch-time like effects or at least intervald...
i thought about this:
switching the video every 24 cycle @ 180bpm would mean 1333ms
so i can set it from 1333 to 1333, but not 1333 + 2666 for example...
