Ignore Column Trigger / Continue playing on other go
kclarkmusic
Post by kclarkmusic »
Lets say I have a clip that is a live input source. I always want this clip to be live. Rather than having to duplicate the clip across all cells in the layer (and decks), it would be great to have an option to allow any currently playing clip (that is set to Ignore Column Trigger) to keep playing when another column is activated.
Re: Ignore Column Trigger / Continue playing on other go
you can set a layer to ignore column trigger, so you don't have to set each empty cell.
kclarkmusic
That did it.
Thanks mate
