Problems on Athlon 1GHZ
frank_
Post by frank_ »
Hiya,
Have any of you experienced some "hanging" problem when running resolume on an Athlon system? Whenever I load a movie and start playing with it, or adding several movies ... the performance becomes sluggish and sometimes comes to a complete stop. I'm on Win98 ...
-- Frank
What resolution and codec are the files you used? please read 'Preparing media' in the manual to optimize your media for playback in resolume.
If you rendered your media at 320x240 with the cinepak codec it should be fine ...
frank_
Post by frank_ »
There is no possibility to go higher in resolution ?
yes you can try 640x480 on some computers/videocards this works just fine ... but the real-time effects might not be real-time anymore ...
