Map Effect presets on Midi APC40
e3pro
Post by e3pro »
Hey guys,
Im mapping an APC 40 and I want to assign effect presets to buttons so different buttons will launch different presets. Anyone know if this is possible. APC40 is in Generic mode.
Re: Map Effect presets on Midi APC40
I don't think you can recall effect presets via midi, but
you could place all your effects with different presets, then assign the buttons to the effect bypasses.
