Hi!
I have 9 Layer, which opacity is controlled by Artnet over a GrandMA Lightdesk.
I created a chaser for this 9 Layer on the GrandMA, but when this chaser starts, resolume totally messed up.
It jump across the clips and the chase do not work.
Second Problem is, when i controll the opacity over Artnet on 100% at the same time on all 9 Layers, the output goes black and I have to restart Resolume.
Any Ideas?
Artnet Problem
Re: Artnet Problem
what channels do you use in the chaser?
are you using the default DMX map in resolume? you can find the channel list in Preferences-DMX-view DMX channel sheet
Re: Artnet Problem
No. I mapped the channels manualy on the AV-Fader.
Re: Artnet Problem
you haven't removed the default mappings before mapping your channels, have you?
if there are mappings of channels you aren't controlling they will get 0 on their channel, which causes the composition fader to go to 0% for example on ch 1 , causing black output.
Re: Artnet Problem
ok. is it enough to deactivate the "DMX Auto Map " ?
Re: Artnet Problem
Yes, if you are using a custom map the DMX auto map should be disabled. I assume your custom mappings are overlapping with the clip commands of some layers.
-Tyler
-Tyler
Re: Artnet Problem
the problem are not only the duplicate mappings, but all the other channels.thetylerherron wrote:Yes, if you are using a custom map the DMX auto map should be disabled. I assume your custom mappings are overlapping with the clip commands of some layers.
-Tyler
when you send dmx, resolume receives the whole universe of 512 channels even when you are using only 2 -3 of them, all the other channels will have 0 as their value and they will control all kinds of things in the default mapping.
edit: if you want to use the same custom dmx map for every composition without having to remap them every time, have a look at the Preferences directory ContextualDmxShortcuts.xml
it contains the default dmx map, the structure is pretty straightforward, make a backup of it and try edit to your liking, and enable dmx auto map, that 'should' load the edited map on the application level I think.
But for portability, I would recommend using the factory dmx auto map, if the dmx function you need exists in it.
Re: Artnet Problem
I disabled the "DMX Auto Map" yesterday and it worked.
Is there any way to map the Deck selection to one Channel with different values like in the standard Mapping?
