Internal Video from Broadcast Media
teggers
Post by teggers »
Hi Everyone!
I have been using Resolume for a year or so.....
Does anyone know a way to get an internet stream to an input panel.....so I can mix an internal source to a Resolume output? I found a way before El Capitan...(simple internet searches)...but I am stuck right now with not enough brains.
Re: Internal Video from Broadcast Media
syphoner for mac can stream any windows texture to syphon,
so if you want to plug an rtsp stream to resolume, open the stream in vlc, and syphon it,
if you want to view a webpage then syphon from your browser window.
ipcam2syphon is another nice tool for getting ip cameras to syphon.
teggers
Post by teggers »
Thanks for the reply.
I will give this a try.
(apparently. I'm a poet)
mkobzar
Post by mkobzar »
Also you can use vmix software as input source for any types of videos, files, photos, streams and moar. I use it two years long and It really works!
Addany type of input in vmix, switch it to output and push "external output", select vmix in resolume sources, thats all.
You're a poet and you don't even know it.
lightbx
Post by lightbx »
^^ Joris' most helpful post of 2016 :P
francoe
Post by francoe »
mkobzar wrote:Also you can use vmix software
That's a little bit buggy, and just windows!
mkobzar
Post by mkobzar »
Oh, sorry, I did not know that the windows no longer used.
Anyway, this is real way to use any videofiles (not only DXV and QT) and any live video.
