Syphon help/recording video,audio output from resolume
elkogan
Post by elkogan »
I'm not able to get syphon recorder connected to my resolume output. I'm working on a time crunch and just need to be able to record hi res video output of resolume with audio. I tried using Resolume's record function but it force stops on me after 20 seconds or so. Is there another software less confusing then syphon that can do record video/audio output for me?
Here is what I'm doing with syphon recorder thus far...
Inside of Resolume I go to sources, drop syphon into the workflow where all the clips are loaded...and the syphon recorder app is still blank. I feel like I'm missing some basic essential understanding to get this thing working. Can you point me in the right direction?
Re: Syphon help/recording video,audio output from resolume
the syphon source is for input.
go to output menu, you can activate syphon output there.
I usually use openbroadcaster for recording syphon sources.
