Blackmagic HDMI - SDI converter
riverboatg
Post by riverboatg »
Hello Guys :)
How ur you?
I have a Blackmagic HDMI to SDI that doesn't work on my Macbook Pro :/
Can someone help me?
Thanks a Lot!
Samuel
Portugal
Re: Blackmagic HDMI - SDI converter
how are you trying to use it, what's your setup?
Just to make sure you've gone through a basic checklist:
- converter is getting power from the 12V adapter
- converter's firmware has been updated to the most recent release
- HDMI cable and output have been tested
- you're using a resolution supported by the converter
HDMI Format Support:625/25 PAL, 525/23.98 NTSC, 525/29.97 NTSC, 720p50, 720p59.94, 720p60, 1080i50, 1080i59.94, 1080i60, 1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 1080p50, 1080p59.94, 1080p60, 2048 x 1080p23.98, 2048 x 1080p24, 2048 x 1080p25.
as a reminder these converters don't support computer resolutions such as XGA, UXGA, WUXGA etc...
riverboatg
my macbook is from 2010
15''
i7 2.6ghz processor
8gb ram
nVidia GT 330M 512mb
480SSD
it doesn't have thunderbolt just a simple mini display port
sam
portugal
