Nvidia GeForce GTX 960M & Integrated Intel Hd Graphics 530
ketsid18
Post by ketsid18 »
hey guys..
so i have an issue with new laptop....
installed a Resolume Arena 5.0.0 and all the codecs and stuff thats necessery...
but when i choose output screen it crashes.. yes i know i tested already with different cables... different outputs .. HDMI.. Thunderbolt... but well.. no help from that..
also tried Nvidia settings.. set to compatibility mode.. and everything. but welll no..
so wanted to know if theres any solution for this.. or should i try to downgrade to win 8.1 or 7?
cheers..
elgarf
Re: Nvidia GeForce GTX 960M & Integrated Intel Hd Graphics 530
Post by elgarf »
Hi
Which brand laptop is?
First I would recommend you install arena 5.0.4 to make sure you're running the most current version of the software.
eigengeis
Post by eigengeis »
If I may guess, is it a MSI Branded Laptop perhaps?
If so, try closing Nahimic before you start up resolume. That should do the trick.
